Column Width in SW BOM's
Using SW 2004 and its SW's driven BOM. Is there a way to get the column width narrower. I see how once the BOM is in the drawing, you can clic on one of the edges of the column you can drag the width a little. But there is still quite a bit of empty space between the column edge and the letters. I want the letters to be right up agains the column edge.
RE: Column Width in SW BOM's
