pipe material compatibility with distilled water
Is distilled water as corrosive to stainlees steel (316L) as DI water? is copper or aluminum compatible with distilled water?
RE: pipe material compatibility with distilled water
All high purity water should be protected from air to avoid CO2 absorption.
316L > Al >> Cu for piping. The 316L & Al form more stable passive surface oxide films, while Cu dissolves excessively.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
