Check direction of curves and surfaces.
Hello:
How can I check fast(faster than "insert-operation-invert") the direction of curves and surfaces? Is there any property that could be checked?
I need it when I replace published surfaces and contours for solid construction.
thanks
RE: Check direction of curves and surfaces.
Jmuriate - you could hot key using customize-commands-all commands - invert orientation to something not used (example F9).  Press F9, pick line, if you want to invert click ok else click cancel.  Brings it down to 1 button + 2 mouse picks
Derek
