Fine aggregate failing in Reactivity test
We tested the fine aggregates earlier for the reactivity test per ASTM standards, and it passed. Its been couple of months since this test was done.
Now we are about to pour the concrete,and it so happens that the same fine aggregate is failing the reactivity test. The fine aggregate was tested in a different lab earlier. We have stored the fine aggregate in a ready-mix facility close to the project site. What could be the reasons why the same fine aggregate is failing the reactivity test? Has it do with how we stored it? Somebody suggested that we should stir the fine aggregate heap really well before testing it for the reactivity. Need your suggestions. Thanks a lot.
Sushil, PE
Nebraska
RE: Fine aggregate failing in Reactivity test
Don't post same question in multiple forums.  See Concrete Engineering forum.
