Solution Time
Solution Time
Solution Time
Hello, I was wondering if there was an ANSYS utility or a simple macro that could be used to work out the approximate solution time for a model, before it is run? Just to give an idea when a solution may finish.
George
RE: Solution Time
In the Ansys Main Menu at the bottom there is a Run-time Stats Menu.  This should give you exactly what you're looking for.
