Pickling & Passivating
One of our suppliers states in his P&P procedure that duplex steel pipes can be treated for a time "up to 24 hours". Solution used is 10%-16% nitric acid + 5%-8% hydrofluoric acid in water at ambient temperature (10-25 °C)
Isn't it a very long dwell time? Is there any risk of damaging the pipe surface? And besides, are there any methods to speed up the process?
Max
RE: Pickling & Passivating
This is a pickle, not a passivation.
We pickle warm. 20% nitric + 5% HF at about 125-130F.  Only some of the high alloy Ni-Cr-Mo grades take more than 2 hours.  304 usually thakes about 20-30 min.
At low temp you will not get much attack at all.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
