Why not an evaporative (swamp) intercooler?
Knowing the heat of evaporation of water is huge, why not take the hot air from a turbocharger and run it through, what is essentially, a household swamp cooler? It seems that would be the most effective way to get cool, compressed air to the intake ports. The humidified charge would not burn as fast but I wouldn't expect that to be much of a problem.
RE: Why not an evaporative (swamp) intercooler?
What you are talking about is already done by water injection and has been done since at least WW11. See numerous other detailed threads for details.
Have you searched and read the previous threads on this topic. Some of the posts were done by real engineers with real data. You really should read them.
There is little to support that a virtual swamp cooler would provide a greater temperature drop than precise direct injection.
The aircraft of WWII must have had more than a simple garden hose setup to very successfully accomplish the task.
There are others
http://
