nat. frequency analysis in pro/e
i want to determine the natural freq. of a panel that has a 2 hp motor attached to it running at 1160 rpm.
should i create an assembly with the panel and motor and go into the mechanism module and add a motor to simulate the 1160 rpm...? will mechanism be able to tell me the nat. freq. or do have to import that data into mechanica and set up a design study creating a new modal, and new dynamic freq. analysis, then run, the program...?
RE: nat. frequency analysis in pro/e
Tunalover
The amplitude you get out the simple modal analysis is NOT real unless you put the forcing function into it.
Hope this helps.
