Print Measurement results
Okay API gurus,
I'm looking for a macro that will print the results of the measurement dialog box with out having to select all the text, copy, open notepad, paste, print.  Similar functionality can be found in a sketch.  When your in a sketch, hit print button, go find the print out. Thanks.
RE: Print Measurement results
I can't help you with a macro for this, but what I do is use Fastone Capture.  Alt+Print screen will capture a window/object, then print.  Simply move your mouse over open windows or dialog boxes and it will highlight what you want to capture.
http://www.faststone.org/FSCaptureDetail.htm
SW06 SP5.0
Flores
