lower case in drawing title/notes
Hi guys,
It has been normal practice for me both in the UK and in the US to use upper case/capital lettering on drawings.
However, when you have units of measure is it normal to use the appropriate case. For example meters should be m not M.
I thought it was and was trying to verify it in one of the ASME stds but neither my checker or I could find it. The Genium manual seems to say to use the appropriate case but if it does state it in the ASME I'd like to know.
RE: lower case in drawing title/notes
I'm not sure either where it is stated. I will look for it.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Upper case letters shall be used for all lettering on drawings unless lower case letters are required.
Ben Loosli
Sr IS Technologist
L-3 Communications
"Combination SI (Metric) and U.S. Customary Linear Units. Where some inch dimensions are shown on a millimeter-dimensioned drawing, the abbreviation IN. shall follow the inch values. Where some millimeter dimensions are shown on an inch-dimensioned drawing, the symbol mm shall follow the millimeter values."
David
Ken
