thread rolling stainless steel
hellow everyone,emimec here.my problem is i am thread rolling 304 s/s parts for a customer,10-32 unc by 2.9 inches long .on a manual capstan lathe ,spindle speed 750 revs.my thread rolls dont last very long 800 parts per set.this makes the job very expensive.what can i do to increase parts per set.
RE: thread rolling stainless steel
The speed sounds a bit high for stainless, but I need to think about that.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Tool material should be fine. Maybe you should look at the surface finish.
The lower speed will help. You don't have to go real slow, just down a bit.
Rust never sleeps
