Epichlorohydrin through vent tank
While filling a bulk tank with epichlorohydrin from a road tanker, the bulk tank vented or burped and less than 50 pounds emitted. The question is how did this happen. The bulk tank was less than 3/4 full with 70,000 pounds capacity remaining. Liquid level was approximately 10 feet from full. HOW DID THIS HAPPEN?
Nitrogen on tank: 2 lbs
Pump rate: 640 lbs per minute
RE: Epichlorohydrin through vent tank
http
http
What additional information do you think is needed to assist in determining what may have happened.
Other opinions have included entrainment and others have maintained that the tank must have been full, however, we have completeted a mass balence for the last 2 years, (last time tank was empty) and the balence shows 70000 lbs of space remaining at time of incident.
Are you pumping?
Type of pump?
How do you know it burped?
Length of unloading pipe or hose?
Temperature of system?
Diameter of pipe?
Pipe material?
Tank Height?
Tank Diameter?
Fill Connection Height?
ETC...ETC.
You are requesting someone to give you an answer while at the same time, the person know little of what you are doing.
Why don't you hire an engineering firm to do a haz-op review of your system? With the haz-op review, they should look at each piece of equipment and operation in your system.
