Check valve and a Butterfuly valve combo
I am looking for a manufacture/supplier of Check and a butterfly valve combination valve. Also the supplier of back flow preventor valve.
RE: Check valve and a Butterfuly valve combo
By back flow preventer do you mean reduced pressure zone device for preventing contamination of a water supply ?
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
This combination has the bad disadvantage, that you can not replace the check valve without draining and depressurizing the system.
You also have a very special item in your system instead of two "standard" itmes.
Try to contact a check valve manufacturer like Noreva and see if they can offer a butterfly together with their check valve as a package.
