Broken Out Sections disappearing
Dear Folks;
Yesterday I created 2 broken out sections, made enlarged detail views of each and dimensioned them.
Today the broken out sections have disappeared, the detail views now just show hidden lines.
The broken out views still show up in the browser. I've tried editing the depth and redefining the spline I used to create them but no luck.
I thought perhaps broken out sections might have a direction of cut but I cant find any way to edit that.
A third broken out section I created in the drawing shows up fine.
Anyone have any ideas what might cause the sections to dissapear ?
Best Regards
Best Regards
Adrian Dunevein
AAA Drafting Services
www.aaadrafting.com
http://home.cogeco.ca/~adunevein/
SW2006 Office Pro. SP4.1
RE: Broken Out Sections disappearing
Could be a bug, or video card/driver combination, or ???
Can you open the file OK on other machines?
Does the drawing print OK?
If you "save as" eDrawing or jpg do the lines appear?
Try changing the view to draft quality.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
The lines dont appear when I mouse over them. Only the spline appears when I click the broken out section in the browser. It also does not appera in a jpeg or an edwg.
Dear ctopher;
Tried draft quality, that does nothing. Video card is NVidea 900XGL, Driver 6.14.10.5317.
Thing is if the video card was playing up why would one broken out section be showing and the other 2 invisible ?
Best Regards
Adrian Dunevein
www.aaadrafting.com
SW06 SP5.0
Flores
Thanks for all your great suggestions.
The only thing that finally made a difference was closing the drawing completely, and reopening the drawing.
Strangely enough, the broken out sections became visible again after I had to jump on a different job later in the day and had to close out all my work.
I have also had the problem copying drawing borders from one sheet to another. In the process of setting up 2 new drawing borders, I copied in a border prior to modifications while in edit sheet mode. The border did copy in but was invisible.
When you hovering over the entities with the cursor, you could tell there was something there but the only way to make it reappear again was to close out everything and re open it.
So sorry it took me so long to figure that out.
Best Regards
Adrian Dunevein
www.aaadrafting.com
