Substructuring: viewing the solution for the entire model?
I am using substructuring technique in ANSYS for thermo simulation of a large model of a chip and I would like to know is it possible to view the nodal solution of the whole structure at once when all the steps of substructuring are finished? May be someone knows how to do it? I would be very grateful to you for any help.
I can see the solution (influenced by the model) for each single superelement separately after the Expansion Pass is done and the solution for the model also separately (influnced by the superelements) but not everything at once.
Thank you very much in advance.
Best regards
Anton
