Sign of principal stress (S1) : tension or compression
I meshed a plate of glass with shells. Ansys gives me a picture of results (principal stress), with positive and negative values. Stupid question : positive is tension or compression ?
Thanks a lot
Sev
Thanks a lot
Sev
RE: Sign of principal stress (S1) : tension or compression
Why don't you plot the principal stress as vectors. The arows of the vectors tells you about the type of stress (compression or tension).
Alex
PS: I suppose, positive must be tension...
