REDUCING SIZE OF CALL OUTS FROM TOOLBOX PARTS
When I bring a toolbox part into an assembly and then open that part in its own window and create a feature and give it a dimension.... the dimension callouts are huge. Is there a way to reduce the size of the callouts (dimenions)?
RE: REDUCING SIZE OF CALL OUTS FROM TOOLBOX PARTS
Also: Tools/Document Properties/Annotations Display/(select box) Always display text at the same size.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Also Tools > Options > Document Properties > Annotations Font and make sure sizes are set to what you want.
Chris
AutoCAD 06
"wink, wink . . "
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
