Masonry Veneer Anchors
Howdy,
ACI does not provide much in the way of design for stone veneer anchorage requirements. Is there another standard that is useful in design for these? I am trying to determine anchorage spacing for a 4" split-faced limestone veneer anchored to cmu block wall with one-inch cavity (10-15' tall) using typical steel tie anchors that are grouted into the joints of the block and then the veneer.
Is there a rule of thumb for this? I have seen 16" o.c vertical and 32" o.c. horizontal to help with coarsing of the 8" block, but what stresses are of the most concern?
Thanks a lot.
Thanks a lot.
RE: Masonry Veneer Anchors
