TEMA Tubesheet Allowable Stress Values
TEMA RCB-7.132 Defines S as the ‘Code' (ASME VIII) allowable stress in tension for tubesheet material metal temperatures’.  Some alloy materials, such AISI 316, have stress values listed in the Code greater than 66% of yield and less than 90% of yield (ASME II Part D Table1A Note G4), is it permissible to use these higher design stresses for S or should the tubesheet be designed to reduce the amount of deformation by using the lower values?
Would this be different for a U tube exchanger subject to no flange moments or an exchanger with expanded tubes only?
CSGWB
RE: TEMA Tubesheet Allowable Stress Values
Have not been in TEMA for a bit---since UHX. However,I think you should use SecII Part A or B for this instead of Part D. May pay to check on this.
CSGWB, if a gasketed joint is involved, I would use the lower allowables, to reduce the change of developing leaks in the future. It may require a little thicker tubesheet, but could save tons of headaches.
Mike
I have seen the higher values used for welded-in tube sheets where distortion is not an issue.  For bolted I would use the lower values.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
