Question on Ford/Volvo/OMC collaboration
Hi... I found a post from 2004 by TheBlacksmith where he said Volvo Penta entered into a joint venture with OMC and eventually took over the OMC Cobra plant. I would like to know if a 1995 Reinell with OMC Cobra sterndrive running a Cobra 302 engine was built during this joint venture - and if the Ford 302 V-8 engine is similar enough to the automotive model that it would accept finned aluminum valve covers. I'm talking about the ones which which read "Cobra - powered by Ford" as seen here: ww w.rowenash ores.com/p ictures/co bra-valve- covers.jpg. I put a set of those on a 68 Cougar XR-7 I had and it transformed the engine compartment... I'd love to do the same on my Reinell if the covers are a perfect fit as I suspect they might be. Any advice much appreciated, along with any other interesting bits of info on the Ford/Volvo/OMC collaboration.
RE: Question on Ford/Volvo/OMC collaboration
