Error message
Error message
I recieve this message while conducting a soil analysis
Warning "The strain increment is so large that the program will not attempt the plasticity calculation at 391 points"
***ERROR: FIXED TIME INCREMENT IS TOO LARGE
Can anybody guide me, what is wrong because i tried to minimize the fixed time increment,but still recieve the same message
RE: Error message
solution fails to converge.
You should use automatic time increments (with the minimum increment set to a low value) to figure out how small the time increments should be.
RE: Error message
RE: Error message
corus
