adhesive for NEOPRENE coated cloth to rubber foam
I want to find an adhesive that is suitable to adhere NEOPRENE coated cloth to rubber foam.
Need info urgently.
RE: adhesive for NEOPRENE coated cloth to rubber foam
Suggestion: Contact Terry Tompkins @ Royal Adhesives & Sealants Co., 2001 West Washington St., South Bend, Indiana.  Phone: 219-246-5386
To bond the neoprene to rubber foam, I would suggest a polychloroprene.  They are manufactured by all of the big adhesive companies and are usually solvent based.  Several others will work if solvent is not an option.
Expect $12 - $15/ gallon.
I hope I've helped,
John
ipin,
Did you find an adhesive that worked well for your application?
Chris
try hte adhesive for neoprene coated fabric evacuation slides,Goodrich P/N 4-A-1
