Map setting has changed-appears to have DOS commands now
I have done something to Map.  Now when I want to insert an image, such that it uses the Map feature for oreintation (Map drop down, Image"  I no longer get the dialog box, where I can locate the image through an windows explorer type of environment.  I get a command line, and I have to type in the path for it.
Also,  when I go to "save as" I do not get the dialog box, I get only a command line and I have to type in the path and new name.
what have I done, Please help me.
RE: Map setting has changed-appears to have DOS commands now
Set FILEDIA to 1 to restore dialogue boxes for file-type commands.  Related setting is CMDDIA for some command dialogue boxes.
thank you very much.  It worked.
Dan
