Simpson Hanger Choice
I have a 12:12 roof pitch, 11 7/8" TJI 210 roof joist framing into a (2) 1 3/4" LVL valley beam. The Simpson hanger would need to be skewed 45 degrees and sloping 45 degrees, but the tables I am looking at only have a downsloping option for sloped conditions. Are there any with upsloping conditions?
Does that make sense?
Pray like everything depends on God
Work like everything depends on you.
RE: Simpson Hanger Choice
TJ website: www.ilevel.com (they recently changed names, again...)
Simpson website: www.strongtie.com
The catalog does not have everything Simpson manufacture. They also custom build hangers for your specific needs if required.
In addition to the info you have already given, they will also need to know the end reactions (both directions) and the depth of the LVL, and maybe a little more.
You need to follow Whodapookie's advice. Aslo Simpson should be able to do a custom of what you are asking for. On projects I've been involved with, I've used custom hangers sloped down 45 & skewed 45. I've used valley hangers skewed 45 and sloped up 39.
