MS Project question
MS Project question
MS Project question
How do you take a column in your gantt chart view and place it in your resource usage view in MS Project 2003?
RE: MS Project question
Which column?  They don't map 1 to 1.
TTFN
How do you take a column in your gantt chart view and place it in your resource usage view in MS Project 2003?  The column is a customized field.  outline code1
No I don't think that they match 1 to 1.  How would I know?  I tried copy and pasting.
It is the column next to the ID column.  I inserted it there, then I went to tools, customize, fields, the custom outline codes tab...
