Middle Click Rotate
Middle Click Rotate
Middle Click Rotate
Hello all, we all know that middle click rotates your model about the origin.  However, I just discovered that if you middle click on an object you will get some constraints which may be handy:
Middle click - select point : The point becomes the origin of rotation.
Middle click - select edge : The edge becomes your axis of rotation.
Middle click - select face : The face becomes your plane of rotation.
I could only get these to work with flat/straight things, your selection should turn pink and your icon will change to what looks like a line integral.
RE: Middle Click Rotate
This has been around since SW04; I didn't use SW before that so I don't know if this was available before then.
Flores
SW06 SP4.1
That's been around for a long time circa 2000.  It's a great tool if you zoomed in on a large assembly.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
SW2007 doesn't require a wheel click anymore to maintain focus when you rotate. I have to re-teach myself to stop wheel clicking on vertices now.
Steve O
