Vacuum in Addenda 4
Vacuum in Addenda 4
API 650 Addenda 4 now includes an appendix V for considering vacuum. Once I have determined the moment of inertia and the area required for end stiffening at the bottom, I need to compare to the moment and area of the shell and bottom contributing. No problem with the area but when looking at the moment of inertia, can I figure the moment of inertia for each part (shell and then bottom) and add these?
RE: Vacuum in Addenda 4
