Translation of a solid.
I have a casting(I.E. Lower Punch)that I need to move up in the "Z" direction,,,,What is the best way to move it and then be able to delete the old one. When I do this ,,,it seems to make a copy and I can't delete the old one .
RE: Translation of a solid.
Now if you are talking surfaces, in GSD you can use the "No Keep" setting - button will be located 3 to the right from create datum. When you use translate surface it will copy/move the surface then delete the old while renaming the new back to orig. (english conversion of french methodology.)
What command are you using to get 2 solids?
Derek
