Hall effects-reverse output voltage
I'm using Allegro A120x hall effect switches...one of the specs is something called Max Reverse Output Voltage( In this case it's -0.5V.
   What does that mean and how do I not exceed it.  I"m more mechanical so thus the question.
Thanks....
RE: Hall effects-reverse output voltage
Exactly what it says.  Do not reverse bias the output, or you'll damage the output transistor.
TTFN
