Thickening Surface offset.
I have a part with alot of surfaces. When i attempt to thicken the part to the inside it will thicken 0.84mm but no less. it will thicken any larger amount but not any thinner.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Thickening Surface offset.
So I think it's ultimately a problem of having small radius curvature in your surface. Small offsets try to offset too small a radius, whereas larger offsets bypass this problem (in a matter of thinking) by going past the zero-radius offset and regenerating the surface beyond the small-radius curvature.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
