Stud bolts for ASME B16.5 Cl150 flanges
Greetings everybody! I need to figure out the standard for stud bolts with which to connect ASME B16.5 Flanges. Is that ASME B18.2.1 or am I wrong?
RE: Stud bolts for ASME B16.5 Cl150 flanges
ASME B18.2.1 is NOT the standard for stud bolts.
ASME B18.2.1, Square & Hex Head Bolts and Screws, is for bolts with a head on one end and a nut on the other end.
Stud bolts are threaded on each end or continuously threaded for hex nuts to be used on each end.
You might contact:
Texas Bolt Company
Houston, Texas
713-869-7111
or
Standco Industries, Inc.
Houston, Texas
713-224-6311
800-231-6018
NozzleTwister
Houston, Texas
NozzleTwister
Houston, Texas
The studs to be used are listed in ASME B16.5 and B16.47. The standard carbon steel studs and nuts (high tensile) are ASME A193 gr B7 and ASME A194 gr 2H, useg in O&G Ind., refining and any flanged pressure system.
Cheers, gr2vessels
