Zip gaps on imported iges surface data
I used proe 2001 and in that you could redefine the  imported data and get the option to zip gap, tangency etc. How can I do this on Wildfire2? (someone surgested insert new geomety and a geometry tab appears with heal geometry on it, BUT this seem not to do anything on the imported data one step up the tree or if you hilight it. Can anyone help.
RE: Zip gaps on imported iges surface data
RMB the Import Feature, Edit Definition.  You should have a Geometry menu with the Heal functions.
