OptisWorks Ray trace software in SW
I am using OptisWorks ray trace software (OWLM1) within SolidWorks and it has been an excellent tool. Is anyone else out there using this software? I would like to be able to model a GRIN material lens without upgrading my software. Approximating the performance with curved surfaces has been working OK but I need an accurate model. Is anyone aware of a model that can be downloaded?
Harold
SW2007 SP0.0 OW2006 SP4.0
www.lumenflow.com
RE: OptisWorks Ray trace software in SW
That's good to here.  We use an old DOS based 2D ray trace software when we do lense design.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
I suppose if that's all you need then you've saved your company some money. Our Optical Engineer has ZEMAX for the actual lense design work and I use OptisWorks to confirm the mechanical design. SW with OW works well for shifting components around in the ray path for trouble shooting or tolerance stacks too.
Perhaps I should post this over at the Optical systems engineering forum?
Harold
www.lumenflow.com
