Corten vs A572
Corten vs A572
Corten vs A572
We recently designed a piece of equipment using A572 Gr 50 steel.  During fabrication this material was substituted with CORTEN A588.  Is there any downfalls to using this material over the A572?
RE: Corten vs A572
If you go to the web site below
http://www.intlsteel.com/content/products/prod_plate_spec.aspx
Click on the link for Plate Steel Specification Guide. Download the document, and you can review general mechanical properties of the two steel plate specifications.
Off-hand, I see no real problem with using A-588 Corten plate. This is a weathering grade of steel, and it would appear to have similar mechanicals as the A-572 Grade 50. Both plate steels are high strength low alloy grades.
