post builder operator message
I have a problem with post builder I am using mill controls that have a operator message. the problem is the post is putting the operator message in the posted tool path and the machine will not accept it and alarms. I cannot take it out of the mill control because other machine use it. can anybody tell me how to get post builder not to out put it?
thanks charlie
RE: post builder operator message
Why don't you just make another post for that machine.
Also can you close you message with () and make it work?
You could add an operator message procedure to your post that contains nothing. That one should prevent the output.
You could take to default operator message and add it to your post and then make it output nothing.
proc  MOM_operator_message {} {
#_______________________________________________________________________________
# This procedure is executed when the Operator Message command is activated.
         global mom_operator_message mom_operator_message_defined
         global mom_operator_message_status
         global ptp_file_name group_output_file mom_group_name
         global mom_sys_commentary_output
         global mom_sys_control_in
         global mom_sys_control_out
         global mom_sys_ptp_output
         if {[info exists mom_operator_message_defined]} {
           if {$mom_operator_message_defined == 0} { return }
 return }
John Joyce
i Knowledge Solutions
Denver, Colorado
joyce@ikstata.com
www.ikstata.com
