Collector Base Reverse Saturation Current
Does Collector-Base Reverse Saturation Current depend on the applied collector base voltage?
Thank you very much.
RE: Collector Base Reverse Saturation Current
Review your textbook's Ebers-Moll model.
TTFN
In the Microsemi date sheet Icbo is specified as 10uA for Vcb=75V and 10nA for Vcb=60V.
In the circuit I am designing the collector-base reverse saturation current of PNP transistors can eventually turn one PNP transistor at high temp. I ma wandering if the Icbo depends only on temperaure or on the Vcb as well.
In the Microsemi data sheet Icbo for 2N2222 is specified as 10uA for Vcb=75V and 10nA for Vcb=60V
Please use the correct terminology.  Microsemi's datasheet clearly calls Icbo "collector-base cutoff current."  Your usage of "saturation current" is very confusing.
Just to end this charade, leakage current is a function of both voltage and temperature.
TTFN
