Projection welding info
I need to weld 6 bushings to a plate and projection welding appears to be the most cost effective solution. My problem is I cannot find bushings that are commercially available, and I'm not exactly sure how to design the bushing for this process. Can anyone suggest a vendor or advise on the design for the bushings?
Thanks.
Thanks.
RE: Projection welding info
htt
or other Stud Welding products providers.
It seems to me that stud welding is a better description of the process you need.
http://www.welding-advisers.com/
http://www.rbwmfg.com/
Cory
