Mechanica Licensing
Mechanica Licensing
Does anyone really understand the licensing of Pro/Mechanica?
I have the following modules:
Pro/MECHANICA Independent Mode: 159
Pro/MECHANICA INTERFACE: MECUG_INTF
Pro/MECHANICA INTERFACE: MECINTERFCE_INTF
Stand-Alone Pro/MECHANICA STRUCTURE: MECSTRUCENG_ST
Stand-Alone Pro/MECHANICA STRUCTURE: MECSTRUCUI_ST
Pro/ENGINEER Mechanica: MECBASICENG_License
Pro/ENGINEER Mechanica: MECBASICUI_License
We also have a 90 day evaluation of:
Pro/ENGINEER Advanced Mechanica: 211
Pro/ENGINEER Advanced Mechanica: 212
Now can someone tell me if the advantages/disadvantages of the Standalone modules?
Can the Standalone modules do everything that the Advanced Mechanica can?
We have a bolted assembly with preloads and to run the analysis from with Pro/E requires the Adavnced license. What I want to know is if we can the same the analysis from the Standalone licenses we have? If we can't, then we will have to purchase the Advanced module.
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: Mechanica Licensing
As far as I am aware:
PTC has changed the way they package Mechanica. It used to be that you bought Structure and/or Thermal each of which gave full functionality. Now they have changed the packaging to "basic" and "advanced", where basic gives some structural and thermal capabilities, advanced gives all.
The "old" structure license which you have should give you full structural capabilities, and allow you to do preloaded bolts.
Couldn't you test this by temporarily removing the Basic & Advanced licenses from your license pack?
John
Ben Loosli
Sr IS Technologist
L-3 Communications
As far as I've been informed:
The basic license:
Contact: YES
Non-linear geometry: NO if you mean large deformation
Optimisation & update Pro/E model: YES
The Advanced license:
2D Analyses (plane strain, plane stress, 2D axi-sym)
Transient Thermal
Large deformation
Prestress static & modal
Vibration - Dynamic Time/Frequency/Shock/Random
Non Isotropic materials ie. composites
Advanced bolts & weighted links
Advanced mass & springs
FEM meshing for Ansys/Nastran
Independant Mechanica
John
