Projection Welding
Projection Welding
I need to have 6 bushings welded to a plate and projection welding appears to be the most cost effective solution. My problem is I cannot find bushings that are commercially available, and I'm not exactly sure how to design the bushing for this process. Can anyone suggest a vendor or advise on the design for the bushings
RE: Projection Welding
What is the function of your bushings and their size? Can you use a self-clinching bushing that is pressed into your plate?
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Can you design a one-piece spacer instead of 3 separate bushings?
