Assembly Cost Calculation in Inventor
Hi All,
We use Inventor 11.  My question is the following:
Is there a practical way to generate a report containing the BOM and cost (for every componant) within Inventor ? And would this database be "smart" or linkable to excell or access ?
If not, is there any software or plugin that could possibly do this ?
Please note, I do not use Inventor myself.
Any help or pointers are very appreciated.
RE: Assembly Cost Calculation in Inventor
Inventor has fields in its iProperties menus for cost. This field can be added to a BOM and then exported to an access or excell file. That being said, I have exported a BOM into excell before but never into access and I have no idea if there is a way to link the two together so that the exported files update with the model.
The quick answer is yes, you can put that information into Inventor and then get it back out again.
Hi aardvarkdw,
Thanks for your response.
I have noticed the estimated cost field in the iProperties menu, we filled it in for parts but the assembly cost does not add up the cost of the parts, everything has to be input manually.
Can you import iProperties from Excell ?
Excell links with Access so Excell functionnality would be fine with me.
Thanks again
You could use the BOM extractor addin on Charles site, but that does not update automatically.
There are a couple addins out there that I'm pretty sure would do the trick, but I don't use them so I can't give you much advise.
I would post the question to http://www.mcadforums.com/forums/
also, look at the add-ins listed there on Seans site. I'm sure someone will point you to a good solution.
I don't know how much visual basic experience you have but here is a thread from the Autodesk MB that discusses this.
http://tinyurl.com/pedpe
