Temperature Ranges for Bolt Materials
Gentlemen,
Does anyone know wher to find or have information on the Temperature Ranges for Bolt and Nut Material? Thanks...
RE: Temperature Ranges for Bolt Materials
I thought that was were I should be looking, thanks for putting me on the correct path. My only problem with using ASME Section II, Part D, Table 3, is that it does not give you the lowest temperature that the material can be used, it only starts at -20 Deg. F. I know SA-320 is used for Low Temp service, but this table does not list the lowest temp. Thanks again for the help. At least I know I have a starting place...
If you get your hands on a copy of ASME B31.3, see Appendix A, Table A-2 Design Values for Bolting Materials.
As always, you are very helpful. I will and try to return the favor someday.
For carbon steel materials, impact test exemption temperatures for bolts and nuts are given in General Notes (e) and (f) to Figure UCS-66. 'Parts' for other material types (UHA, etc) may also list rules for exemption or MDMT rating for bolts of such materials.
Tom Barsh
Codeware Technical Support
For what it is worth, Charles Becht IV discusses this particular bolt usage issue in his fine book about the ASME B31.3 piping code. "Process Piping: The Complete Guide to ASME B31.3, Second Edition"
htt
Well worth the money....has cleared up a lot of miscellaneous issues that I have had over the years
-MJC
