IDEAS NX 10 Shutdown when printing
When I try to click then print, the ideas will shutdown, Tried to check the error log but found no contents is says only IDEAS shutdown abnormally. I dont know to fix this I need your expertise.
For more details of machine:
Its SGI running on IRIX 6.5
hope you could help me
thanks
RE: IDEAS NX 10 Shutdown when printing
I have had this problem.  If I remember right the problem was the way "my documents" was mapped.  Go into your my documents properties and change it from a network server address to a standard address.  even if it is pointing to the same spot.
for instance instead of \\server1\user\My Documents
change it to H:\My Documents
worked for us here
