SHELLING STRATEGY
SHELLING STRATEGY
I often have issues when it comes to shelling parts....Shelling feature failing due to the minimum curvature issue, etc. I was wondering if people could share there techniques, timing, methods of when to shell the part. Do you add the details (fillets, cuts, chamfers) to get far along on the part, then roll back to shell? Do you make the basic form of the part then shell and then continue on adding the fillets, and other small detailing.... that otherwise would cause a shell failure later down the line......etc.?
Thanks.
John
Thanks.
John
RE: SHELLING STRATEGY
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
If the inner rads can be non-concentric to the outer ones, then shelling before the outer rads would be better.
An alternative is to create a surface of the required inner form & then thicken outwards.
Another alternative is to create inner & outer bodies, then use the Combine-Subtract function.
