Difference between Punch & Die and Two Profiles?
Does anyone know the difference between Parameters choice: Punch & Die and Two Profiles?
It's in module: Sheet Metal Design
CATIA V5r16
RE: Difference between Punch & Die and Two Profiles?
hi,
As i know that people will calls,
male shape profile will be a punch.
female shape profile will be a die.
Punch can be upper die or lower die. In same way die can be upper die or lower die. Its depends on die design or shape of the part.
             I will say that call by upper die and lower die instead of calling punch or die.
Thank you,
srinivas
