removing the volume of an intersected part.
We have an assembly that contains small parts/wiring/connections that is then encapsulated in a mold using a epoxy resin. I need to be able to remove the volume of those small parts from the mold in Pro/e 2000i2.
I'm having brain freeze now on how to remove a volume of one part that is intersected with another. I have done it before but it has been a few years since I needed to do something like this.
RE: removing the volume of an intersected part.
