RC column to reduce eccentricity?
Hello all, it's been a while since I posted, busy with work and studies. I am faced with a 280' wide PEMB containing a large moment and reaction at the exterior footings at the slab edge. To try to overcome this eccentricity, I was thinking of using a short RC column to support the building frame. This column would be about 24" tall and extend from the slab to a footing (loaded concentrically) below grade. Has anyone used this technique? Does anyone see any problems?
Thanks!
Thanks!
RE: RC column to reduce eccentricity?
