DIMENSION TRICK
DIMENSION TRICK
DIMENSION TRICK
One of my students fumbled upon this...
Sketch 2 circles & then dimension between them... the circles, not the center points. But hold the SHIFT key after the 1st click & see what happens. It gives you more control over the dimension placement. I tried looking this up in the HELP menus... but not knowing what to call it - I found nothing.
But I like it a lot...
Windows XP / Logitech "Premium" Optical mouse
SolidWorks 2006 SP4.1 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
RE: DIMENSION TRICK
In the help, choose the "Index" tab and type "Dimensions" and click "Between Arcs and Circles".
RE: DIMENSION TRICK
Like Mama always said: "If it'a been a skake, It'a bit you."
Thanks...
Lava Lamp
www.Tate3d.com
