Opening Inventor 9 files with Inventor 10
I am trying to open files with Inventor 10 pro but created with Inventor 9 pro but get the following message:- The following location(s)in your project are currently unavailable. If you continue opening the file, you may experience significantly slower performance than normal.
The files open ok then, if I save the file, then re open I still get the same message.
Any ideas????
Any ideas????
RE: Opening Inventor 9 files with Inventor 10
In R10 all the fittings were rolled into the content center, and publishing them (along with library file locations) changed a bit. I haven't had to do any significant work on R9 piping files since the move to R10 so I can't tell you exactly how to fix it....but I figured I would give you a starting point.
Cheers
They may also be linked to a spreadsheet that got moved or changed?
Just a couple possiblities... can't think of any other easy options that would let the file open.
