User written subroutine
Hi all,
I want to determine the Displacement Velocity and Acceleration of a damper under simulation to calculate the Damper Force in a user written subroutine. Descibing the part and marker statement are not supporetd by fortran compiler. Can any body give me some tips how this can be done.
This is how I have dont it at the moment
PART/01, MASS=1, IM=280.2, -567.0, 345.0 &
&,IP=100.0,100.0,100.0
MARKER/0101, QP=267.0, -600.0, 180.0
! Defining upper damper mount
PART/02, MASS=1, IM=293.4, -534.0, 510.0 &
MARKER/0201 QP=307.0, -500.0, 680.0
! Determine displacement
DIS, FUNCTION=DM(01,02)
! Determine velocity
VEL, FUNCTION=VM(01,02)
! Determine acceleration
ACC, FUNCTION=ACCM(01,02)
RE: User written subroutine
Have you read the help section on user-written subroutines? particularly SFOSUB? Which even includes an example...
Cheers
Greg Locock
The tip you gave me for using SFOSUB as a starting point for my subroutine was really useful.
I dont understand how will the software get he valuse of PAR ( 4,5,6,7 ) or am i supposed to mention them.
PAR(1,2,3) are the co-ordinatres of the marker whoes vel./disp. is being measured in 'z' direction. Shall I mention them as well. And what if I want to measure DM?
I dont have a clue what does IPAR( 1 )  = NINT(PAR( 1 )) mean.
Can you please explain.
Yes, you have to explicitly pass the variables to your sub, and read the answers back in to the Solver.
The easiest example of functional code in the tutorials is the ABS controller example, which includes all the code, and it works.
Cheers
Greg Locock
