assembly configurations??
Just wondering how to create an assembly config.
I have assembled several components into a "unfolded" state, but now I want to create a configuration for a folded state to show my customers. How hard is it to do this??
jeep in mind I am using SW 2007
thanks in advance
RE: assembly configurations??
Do you know how to create configs in a part? Same way in assy.
Unfolded/folded states ... as in sheetmetal or exploded?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
From your post, I interpret that you are assembling flattened sheet metal parts. Is that correct? If not, can you explain what you mean by "assembled several components into a "unfolded" state"?
Whatever it is you are trying to do, the default finished assembly (using default finished parts) is usually created before any special configs are created.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
sorry for the confussion,
I am designing a folding guitar stand, and right now I have assembled it as if it was unfolded. That is with the legs and support arms "open". I now want to create a configuration with everything closed or in a colapsed state, with the legs, etc folded up.
I hope this helps in clearing up my question,
emc-
That makes it much clearer! smile
There are a couple of ways to go, depending on what kind of mating scheme you've used so far.  If you have angle mates you can create your other configuration and edit the dimensions of the angle mates such that the stand is folded.  Alternately, create your new configuration, supress mates in that configuration that make the stand unfolded, and add mates that make it folded.
